Linearization of a coupled system of nonlinear elasticity and fluid - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
We model the coupled system formed by an incompressible, irrotational fluid and a nonlinear elastic body. We work with large displacement, small deformation elasticity (or St Venant elasticity), which makes the problem very interesting from the physical point of view. The elastic body is three-dimensional $\Omega \in \mathbb{R}^3$, and thus it can not be reduced to its boundary $\Gamma$ (like in the case of a membrane or a shell). In this paper, we study the static problem, which contrary to common belief, it is more subtle than the dynamical one (since in real life, evolution is more plausible than equilibrium).
BZ3.pdf (196.73 Ko) Télécharger le fichier
inria-00442954 , version 1 (24-12-2009)
  • HAL Id : inria-00442954 , version 1
Lorena Bociu, Jean-Paul Zolesio. Linearization of a coupled system of nonlinear elasticity and fluid. [Research Report] Inria. 2009. ⟨inria-00442954⟩
180 Consultations
201 Téléchargements
