s'authentifier
version française rss feed
inria-00443634, version 1
Real-time Rendering of Heterogeneous Translucent Objects with Arbitrary Shapes
Yajun Wang a123, Jiaping Wang 3, Nicolas Holzschuch () a1, Kartic Subr () a1, Jun-Hai Yong 4, Baining Guo 23
Computer Graphics Forum 29, 2 (2010) 497-506
Résumé : We present a real-time algorithm for rendering translucent objects of arbitrary shapes. We approximate the scattering of light inside the objects using the diffusion equation, which we solve on-the-fly using the GPU. Our algorithm is general enough to handle arbitrary geometry, heterogeneous materials, deformable objects and modifications of lighting, all in real-time. In a pre-processing step, we discretize the object into a regular 4-connected structure (quadgraph). Due to its regular connectivity, this structure is easily packed into a texture and stored on the GPU. At runtime, we use the quadgraph stored on the GPU to solve the diffusion equation, in real-time, taking into account the varying input conditions: incoming light, object material and geometry. We handle deformable objects, provided the deformation does not change the topological structure of the objects.
  • Domaine : Informatique/Synthèse d'image et réalité virtuelle
  • inria-00443634, version 1
  • oai:hal.inria.fr:inria-00443634
  • Contributeur :
  • Soumis le : Jeudi 31 Décembre 2009, 17:29:31
  • Dernière modification le : Vendredi 3 Septembre 2010, 11:39:13
tous les articles de la base du CCSd...
