Realization of a Magnet Using an Antiferromagnetic Phase of Single-Chain Magnets - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Physical Review Letters Année : 2009
A system presenting an antiferromagnetic (AF) phase of Single-Chain Magnets (SCMs) is studied at low temperatures. The phase diagram is first discussed to specify the magnitude of the interchain couplings. Then, we show experimentally and theoretically that slow relaxation of the magnetization can still be observed in the AF phase, with a maximum of the relaxation time close to the AF-paramagnetic phase transition. This counter intuitive result shows that materials presenting such an ordered state can be used to design high temperature magnets using SCM-based materials.
coulon2.pdf (774.61 Ko) Télécharger le fichier
inria-00443849 , version 1 (12-03-2013)
C. Coulon, Hitoshi Miyasaka, Wolfgang Wernsdorfer, Thierry Colin, Rodolphe Clérac. Realization of a Magnet Using an Antiferromagnetic Phase of Single-Chain Magnets. Physical Review Letters, 2009, 102, pp.167204. ⟨10.1103/PhysRevLett.102.167204⟩. ⟨inria-00443849⟩
115 Consultations
453 Téléchargements
