A Useful Form of the Abel Bound and Its Application to Estimator Threshold Prediction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Signal Processing Année : 2007
This correspondence investigates the Abel bound in order to predict the estimators mean square error (mse) threshold effect. A tractable and computationally efficient form of this bound is derived. This form combines the Chapman–Robbins and the Cramér–Rao bounds. This bound is applied to a data-aided carrier frequency estimation problem for which a closed-form expression is provided. An indicator of the signal-to-noise ratio threshold is proposed. A comparison with recent results on the Barankin bound (Chapman–Robbins version) shows the superiority of the Abel-bound version to predict the mse threshold without increasing the computational complexity.
RNFL07.pdf (282.69 Ko) Télécharger le fichier
inria-00444722 , version 1 (07-01-2010)
  • HAL Id : inria-00444722 , version 1
Alexandre Renaux, L. Najjar-Atallah, Philippe Forster, Pascal Larzabal. A Useful Form of the Abel Bound and Its Application to Estimator Threshold Prediction. IEEE Transactions on Signal Processing, 2007, 55 (5), pp.2365-2369. ⟨inria-00444722⟩
122 Consultations
381 Téléchargements
