Efficient and Flexible Dynamic Reconfiguration for Multi-Context Architectures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Integrated Circuits and Systems Année : 2009
Dynamic reconfiguration is possible on both fine-grain and coarse-grain architectures. One of the used methodology used consists in the use of multi-context architectures. Unfortunately, the multi- ple contexts bring power and area overhead. This paper introduces the Dynamic Unifier and reConfigurable blocK (DUCK) concept, a new structure to perform efficiently dynamic reconfigura- tion on both custom designed fine-grain and coarse grain architectures. The DUCK allows to sepa- rate the configuration path and the configuration registers which facilitates simultaneous configuration and computing steps. The reconfiguration process is presented in detail, and synthesis results are given for different structures. Our solution is finally validated with the implementation of a WCDMA (Wideband Code Division Multiple Access) receiver on a multi-context embedded FPGA and on the dynamically reconfigurable processor DART. This implementation demonstrates the inter- est and the efficiency of the use of dynamic reconfiguration and the proposed flexible structure.
lallet09c.pdf (365.25 Ko) Télécharger le fichier
inria-00446054 , version 1 (12-01-2010)
  • HAL Id : inria-00446054 , version 1
Julien Lallet, Sébastien Pillement, Olivier Sentieys. Efficient and Flexible Dynamic Reconfiguration for Multi-Context Architectures. Journal of Integrated Circuits and Systems, 2009, 4 (1), pp.36-44. ⟨inria-00446054⟩
213 Consultations
175 Téléchargements
