On the Membership Problem for Non-Linear Abstract Categorial Grammars - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Logic, Language and Information Année : 2010
In this paper we show that the membership problem for second order non- linear Abstract Categorial Grammars is decidable. A consequence of that result is that Montague-like semantics yield to a decidable text generation problem. Furthermore the proof we propose is based on a new tool, Higher Order Intersection Signatures, which grasps statically dynamic properties of λ-terms and presents an interest in its own.
generation.pdf (192.5 Ko) Télécharger le fichier
inria-00446785 , version 1 (13-01-2010)
Sylvain Salvati. On the Membership Problem for Non-Linear Abstract Categorial Grammars. Journal of Logic, Language and Information, 2010, 19 (2), pp.163-183. ⟨10.1007/s10849-009-9110-0⟩. ⟨inria-00446785⟩
240 Consultations
212 Téléchargements
