Human Motion Tracking by Registering an Articulated Surface to 3-D Points and Normals
We address the problem of human motion tracking by registering a surface to 3-D data. We propose a method that iteratively computes two things: Maximum likelihood estimates for both the kinematic and free-motion parameters of a kinematic human-body representation, as well as probabilities that the data are assigned either to a body part, or to an outlier cluster. We introduce a new metric between observed points and normals on one side, and a parameterized surface on the other side, the latter being defined as a blending over a set of ellipsoids. We claim that this metric is well suited when one deals with either visual-hull or visual-shape observations. We illustrate the method by tracking human motions using sparse visual-shape data (3-D surface points and normals) gathered from imperfect silhouettes.
Horaud-TPAMI2009.pdf (1.37 Mo)
Télécharger le fichier
Slides-HoraudTPAMI09.pdf (13.65 Mo)
TPAMI2009_additional.pdf (6.07 Mo)
taekwendo2.avi (23.45 Mo)
Format : Figure, Image
Format : Autre
Format : Autre
Format : Vidéo
