An Efficient Numerical Inverse Scattering Algorithm for Generalized Zakharov-Shabat Equations with Two Potential Functions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2010
The inverse scattering problem for coupled wave equations has various applications such as waveguide filter design and electric transmission line fault diagnosis. In this paper, an efficient numerical algorithm is presented for solving the inverse scattering problem related to generalized Zakharov-Shabat equations with two potential functions. Inspired by the work of Xiao and Yashiro on Zakharov-Shabat equations with a single potential function, this new algorithm considerably improves the numerical efficiency of an algorithm proposed by Frangos and Jaggard, by transforming the original iterative algorithm to a one-shot algorithm.
Automatique
numerical_method_for_GLM_Z-S_with_two_complex_potential_functions.pdf (79.7 Ko) Télécharger le fichier
inria-00447358 , version 1 (14-01-2010)
  • HAL Id : inria-00447358 , version 1
Huaibin Tang, Qinghua Zhang. An Efficient Numerical Inverse Scattering Algorithm for Generalized Zakharov-Shabat Equations with Two Potential Functions. [Research Report] 2010. ⟨inria-00447358⟩
102 Consultations
155 Téléchargements
