s'authentifier
version française rss feed
inria-00448729, version 2
Class invariants by the CRT method
Andreas Enge () 1, Andrew V. Sutherland a2
Ninth Algorithmic Number Theory Symposium ANTS-IX 6197 (2010) 142-156
Résumé : We adapt the CRT approach for computing Hilbert class polynomials to handle a wide range of class invariants. For suitable discriminants $D$, this improves its performance by a large constant factor, more than 200 in the most favourable circumstances. This has enabled record-breaking constructions of elliptic curves via the CM method, including examples with $|D|>10^{15}$.
  • inria-00448729, version 2
  • oai:hal.inria.fr:inria-00448729
  • Contributeur :
  • Soumis le : Samedi 1 Mai 2010, 15:33:06
  • Dernière modification le : Jeudi 7 Avril 2011, 17:54:50
tous les articles de la base du CCSd...
