Interacting path systems for credit portfolios risk analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2010
This Note introduces an algorithm (referred to as interacting path systems algorithm, IPaS) based on the first Author multilevel splitting technique and suited to the analysis of multiple defaults in credit portfolios. A full development of this Note incorporating technical details and a survey of the use of Interacting Particle Systems in the field of credit risk, \it Interacting path systems for credit risk, is submitted for publication in \it Recent Advancements in the Theory and Practice of Credit Derivatives, Eds T. Bielecki, D. Brigo, F. Patras, Bloomberg Press (2011). The reader is referred to this article for further details.
RR-7196.pdf (155.6 Ko) Télécharger le fichier
inria-00454005 , version 1 (07-02-2010)
  • HAL Id : inria-00454005 , version 1
Pierre del Moral, Frédéric Patras. Interacting path systems for credit portfolios risk analysis. [Research Report] RR-7196, INRIA. 2010, pp.9. ⟨inria-00454005⟩
236 Consultations
194 Téléchargements
