Finding Induced Subgraphs via Minimal Triangulations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Potential maximal cliques and minimal separators are combinatorial objects which were introduced and studied in the realm of minimal triangulations problems including Minimum Fill-in and Treewidth. We discover unexpected applications of these notions to the field of moderate exponential algorithms. In particular, we show that given an n-vertex graph G together with its set of potential maximal cliques Pi_G, and an integer t, it is possible in time |Pi_G| * n^(O(t)) to find a maximum induced subgraph of treewidth t in G; and for a given graph F of treewidth t, to decide if G contains an induced subgraph isomorphic to F. Combined with an improved algorithm enumerating all potential maximal cliques in time O(1.734601^n), this yields that both problems are solvable in time 1.734601^n * n^(O(t)).
fomin_85.pdf (216.05 Ko) Télécharger le fichier
inria-00455360 , version 1 (10-02-2010)
  • HAL Id : inria-00455360 , version 1
Fedor V. Fomin, Yngve Villanger. Finding Induced Subgraphs via Minimal Triangulations. 27th International Symposium on Theoretical Aspects of Computer Science - STACS 2010, Inria Nancy Grand Est & Loria, Mar 2010, Nancy, France. pp.383-394. ⟨inria-00455360⟩
Collections
STACS2010
60 Consultations
139 Téléchargements
