Branching-time model checking of one-counter processes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
One-counter processes (OCPs) are pushdown processes which operate only on a unary stack alphabet. We study the computational complexity of model checking computation tree logic (CTL) over OCPs. A PSPACE upper bound is inherited from the modal mu-calculus for this problem. First, we analyze the periodic behaviour of CTL over OCPs and derive a model checking algorithm whose running time is exponential only in the number of control locations and a syntactic notion of the formula that we call leftward until depth. Thus, model checking fixed OCPs against CTL formulas with a fixed leftward until depth is in P. This generalizes a result of the first author, Mayr, and To for the expression complexity of CTL's fragment EF. Second, we prove that already over some fixed OCP, CTL model checking is PSPACE-hard. Third, we show that there already exists a fixed CTL formula for which model checking of OCPs is PSPACE-hard. For the latter, we employ two results from complexity theory: (i) Converting a natural number in Chinese remainder presentation into binary presentation is in logspace-uniform NC^1 and (ii) PSPACE is AC^0-serializable. We demonstrate that our approach can be used to answer further open questions.
goeller.pdf (189.18 Ko) Télécharger le fichier
inria-00455367 , version 1 (10-02-2010)
  • HAL Id : inria-00455367 , version 1
Stefan Göller, Markus Lohrey. Branching-time model checking of one-counter processes. 27th International Symposium on Theoretical Aspects of Computer Science - STACS 2010, Inria Nancy Grand Est & Loria, Mar 2010, Nancy, France. pp.405-416. ⟨inria-00455367⟩
Collections
STACS2010
125 Consultations
323 Téléchargements
