Weakening Assumptions for Deterministic Subexponential Time Non-Singular Matrix Completion - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In (Kabanets, Impagliazzo, 2004) it is shown how to decide the circuit polynomial identity testing problem (CPIT) in deterministic subexponential time, assuming hardness of some explicit multilinear polynomial family for arithmetical circuits. In this paper, a special case of CPIT is considered, namely low-degree non-singular matrix completion (NSMC). For this subclass of problems it is shown how to obtain the same deterministic time bound, using a weaker assumption in terms of determinantal complexity. Hardness-randomness tradeoffs will also be shown in the converse direction, in an effort to make progress on Valiant's VP versus VNP problem. To separate VP and VNP, it is known to be sufficient to prove that the determinantal complexity of the m-by-m permanent is $m^{\omega(\log m)}$. In this paper it is shown, for an appropriate notion of explicitness, that the existence of an explicit multilinear polynomial family with determinantal complexity m^{\omega(\log m)}$ is equivalent to the existence of an efficiently computable generator $G_n$ for multilinear NSMC with seed length $O(n^{1/\sqrt{\log n}})$. The latter is a combinatorial object that provides an efficient deterministic black-box algorithm for NSMC. ``Multilinear NSMC'' indicates that $G_n$ only has to work for matrices $M(x)$ of $poly(n)$ size in $n$ variables, for which $det(M(x))$ is a multilinear polynomial.
Jansen09final.pdf (235.5 Ko) Télécharger le fichier
inria-00455738 , version 1 (11-02-2010)
  • HAL Id : inria-00455738 , version 1
Maurice Jansen. Weakening Assumptions for Deterministic Subexponential Time Non-Singular Matrix Completion. 27th International Symposium on Theoretical Aspects of Computer Science - STACS 2010, Inria Nancy Grand Est & Loria, Mar 2010, Nancy, France. pp.465-476. ⟨inria-00455738⟩
Collections
STACS2010
59 Consultations
64 Téléchargements
