Unsatisfiable Linear CNF Formulas Are Large, and Difficult to Construct Explicitely - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We call a CNF formula linear if any two clauses have at most one variable in common. We show that there exist unsatisfiable linear k-CNF formulas with at most 4k^2 4^k clauses, and on the other hand, any linear k-CNF formula with at most 4^k/(8e^2k^2) clauses is satisfiable. The upper bound uses probabilistic means, and we have no explicit construction coming even close to it. One reason for this is that unsatisfiable linear formulas exhibit a more complex structure than general (non-linear) formulas: First, any treelike resolution refutation of any unsatisfiable linear k-CNF formula has size at least 2^(2^(k/2-1))$. This implies that small unsatisfiable linear k-CNF formulas are hard instances for Davis-Putnam style splitting algorithms. Second, if we require that the formula F have a strict resolution tree, i.e. every clause of F is used only once in the resolution tree, then we need at least a^a^...^a clauses, where a is approximately 2 and the height of this tower is roughly k.
scheder.pdf (232.72 Ko) Télécharger le fichier
inria-00455809 , version 1 (11-02-2010)
  • HAL Id : inria-00455809 , version 1
Dominik Scheder. Unsatisfiable Linear CNF Formulas Are Large, and Difficult to Construct Explicitely. 27th International Symposium on Theoretical Aspects of Computer Science - STACS 2010, Inria Nancy Grand Est & Loria, Mar 2010, Nancy, France. pp.621-632. ⟨inria-00455809⟩
Collections
STACS2010 TDS-MACS
116 Consultations
619 Téléchargements
