Model-Based Tests for Access Control Policies - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
We present a model-based approach to testing access control requirements. By using combinatorial testing, we first automatically generate test cases from and without access control policies- i.e., the model and assess the effectiveness of the test suites by means of mutation testing. We also compare them to purely random tests. For some of the investigated strategies, non-random tests kill considerably more mutants than the same number of random tests. Since we rely on policies only, no information on the application is required at this stage. As a consequence, our methodol- ogy applies to arbitrary implementations of the policy decision points
mouelhi08a.pdf (500.18 Ko) Télécharger le fichier
inria-00456952 , version 1 (16-02-2010)
  • HAL Id : inria-00456952 , version 1
Alexander Pretschner, Tejeddine Mouelhi, Yves Le Traon. Model-Based Tests for Access Control Policies. ICST 2008 : First IEEE International Conference on Software, Testing, Verification and Validation, April 9-11, Lillehammer, Norway, RSM - Dépt. Réseaux, Sécurité et Multimédia (Institut TELECOM ; TELECOM Bretagne), ETH - Eidgenössische Technische Hochschule Zürich (ETH Zurich), 2008, Lillehammer, Norway. ⟨inria-00456952⟩
239 Consultations
461 Téléchargements
