Increasing Reuse in Component Models through Genericity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
A current limitation to component reusability is that component models target to describe a deployed assembly and thus bind the behavior of a component to the data-types it manipulates. This paper studies the feasibility of supporting genericity within component models, including component and port types. The proposed approach works by extending the meta-model of an existing component model. It is applied to the SCA component model; a working prototype shows its feasibility.
inria-00457905 , version 1 (18-02-2010)
Julien Bigot, Christian Pérez. Increasing Reuse in Component Models through Genericity. Proceedings of the 11th International Conference on Software Reuse, ICSR '09, Sep 2009, Falls Church, VA, United States. pp.21-30, ⟨10.1007/978-3-642-04211-9⟩. ⟨inria-00457905⟩
88 Consultations
0 Téléchargements
