Supporting Heterogeneity in Data Driven Sensor Network Macroprogramming - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2009
Support for heterogeneity has been incorporated within a Macroprogramming framework. Policies for handling runtime and data routing for communication between nodes in a heterogeneous network were designed and implemented. Then, Macroprogramming support was added to compile Macroprograms and generate code for the heterogeneous network.
HIPC20092.pdf (177.16 Ko) Télécharger le fichier
inria-00458907 , version 1 (22-02-2010)
  • HAL Id : inria-00458907 , version 1
Mahanth K. Gowda, Animesh Pathak. Supporting Heterogeneity in Data Driven Sensor Network Macroprogramming. Second student research symposium on High Performance Computing (HPC 2009), Dec 2009, Kochi, India. ⟨inria-00458907⟩
75 Consultations
47 Téléchargements
