Srijan: a graphical toolkit for sensor network macroprogramming - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Macroprogramming is an application development technique for wireless sensor networks (WSNs) where the developer specifies the behavior of the system, as opposed to that of the constituent nodes. In this proposed demonstration, we would like to present Srijan, a toolkit that enables application development for WSNs in a graphical manner using data-driven macroprogramming. It can be used in various stages of application development, viz. i) specification of application as a task graph, ii) customization of the autogenerated source files with domain-specific imperative code, iii) specification of the target system structure, iv) compilation of the macroprogram into individual customized runtimes for each constituent node of the target system, and finally v) deployment of the auto generated node-level code in an over-the-air manner to the nodes in the target system. The current implementation of Srijan targets both the Sun SPOT sensor nodes and larger nodes with J2SE. Our demonstrattion will encourage users to perform end-to-end WSN application development on the SPOTs using Srijan.
esec41do-pathak.pdf (301.81 Ko) Télécharger le fichier
inria-00459353 , version 1 (23-02-2010)
Animesh Pathak, Mahanth K. Gowda. Srijan: a graphical toolkit for sensor network macroprogramming. 7th joint meeting of the European software engineering conference and the ACM SIGSOFT symposium on The foundations of software engineering, Aug 2009, Amsterdam, Netherlands. pp.301-302, ⟨10.1145/1595696.1595752⟩. ⟨inria-00459353⟩
139 Consultations
179 Téléchargements
