How Fast can Virtual Amoebae Aggregate? Analysis for the Optimal Firing Rate in an Instance of the Reaction-Diffusion-Chemotaxis Aggregation Scheme - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2010
Decentralised gathering is a challenging problem in systems involving numerous identical agents. In our current work we analyse the dynamics of a gathering model that is based on virtual amoebae that fire reaction-diffusion waves with a given probability. Interestingly, it has been shown that there exists a tuning of this probability that minimises the aggregation time. Our study is aimed at experimentally measuring this optimal value and analysing how it is related to the dynamics of the model.
preprintOptimalLmabda-amybia.pdf (243.83 Ko) Télécharger le fichier
inria-00462156 , version 1 (08-03-2010)
  • HAL Id : inria-00462156 , version 1
Nikolaos Vlassopoulos, Nazim A. Fatès. How Fast can Virtual Amoebae Aggregate? Analysis for the Optimal Firing Rate in an Instance of the Reaction-Diffusion-Chemotaxis Aggregation Scheme. 2010. ⟨inria-00462156⟩
179 Consultations
96 Téléchargements
