Construction of very high order residual distribution schemes for steady inviscid flow problems on hybrid unstructured meshes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2010
In this paper we consider the very high order approximation of solutions of the Euler equations. We present a systematic generalization of the Residual Distribution method of \cite{ENORD} to very high order of accuracy, by extending the preliminary work discussed in \cite{abgrallLarat} to systems and hybrid meshes. We present extensive numerical validation for the third and fourth order cases with Lagrange finite elements. In particular, we demonstrate that we an both have a non oscillatory behavior, even for very strong shocks and complex flow patterns, and the expected accuracy on smooth problems.
RR-7236.pdf (5.83 Mo) Télécharger le fichier
inria-00464799 , version 1 (18-03-2010)
  • HAL Id : inria-00464799 , version 1
Remi Abgrall, Adam Larat, Mario Ricchiuto. Construction of very high order residual distribution schemes for steady inviscid flow problems on hybrid unstructured meshes. [Research Report] RR-7236, INRIA. 2010, pp.60. ⟨inria-00464799⟩
544 Consultations
248 Téléchargements
