Influence of False Congestion Alarms on Performance for Congestion Control based on Dynamic Window Flow Mechanism in Wireless Networks
This paper aims to 1) investigate the influence of false congestion alarms on the performance of dynamic window flow control (DWFC) in a network environment where the bit error rate is not negligible such as wireless networks and 2) provide a fundamental insight into this issue for TCP
