Node Placement for Connected Coverage in Sensor Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2003
We address the problem of optimal node placement for ensuring connected coverage in sensor networks. We consider two different practical scenarios. In the first scenario, a certain region (or a set of regions) are to be provided connected coverage, while in the second case, a given set of n points are to be covered and connected. For the first case, we provide solutions that are within a small factor of the optimum. For the second case, we present an algorithm that runs in polynomial time, and guarantees a constant factor approximation ratio.
kar-node.pdf (76.36 Ko) Télécharger le fichier
inria-00466114 , version 1 (22-03-2010)
  • HAL Id : inria-00466114 , version 1
Koushik Kar, Suman Banerjee. Node Placement for Connected Coverage in Sensor Networks. WiOpt'03: Modeling and Optimization in Mobile, Ad Hoc and Wireless Networks, Mar 2003, Sophia Antipolis, France. 2 p. ⟨inria-00466114⟩
Collections
WIOPT2003
1018 Consultations
965 Téléchargements
