Capacity and Decentralized Admission/Congestion Control in the Up and Down-link of the CDMA Networks
This work concerns the evaluation of the global up and down-link capacity of CDMA networks under maximal power constraints, with a special emphasis on the limitations of capacity due to inter-cell and own-cell interferences. More precisely we analyze the maximal number of users that such a network can serve at a given bit-rate and/or the maximal bit-rates that such a network can provide to a given user population ...
