Performance Characterization of a Bluetooth Piconet with Multi–Slot Packets - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
In this paper we present a framework for performance evaluation of a Bluetooth piconet using multislot packets. In particular, under some classical assumptions, we develop a model of a Bluetooth network and derive the complete statistics of the one–hop delay, and other significant metrics such as the channel utilization parameter. Stability conditions are investigated and it is shown that the use of multi–slot packets enlarges the achievable rate region. Simulations results are then shown, which validate the proposed analysis.
Miorandi-performance.pdf (134.71 Ko) Télécharger le fichier
inria-00466702 , version 1 (25-03-2010)
  • HAL Id : inria-00466702 , version 1
Daniele Miorandi, Carlo Caimi, Andrea Zanella. Performance Characterization of a Bluetooth Piconet with Multi–Slot Packets. WiOpt'03: Modeling and Optimization in Mobile, Ad Hoc and Wireless Networks, Mar 2003, Sophia Antipolis, France. 6 p. ⟨inria-00466702⟩
Collections
WIOPT2003
76 Consultations
131 Téléchargements
