BitTorrent Experiments on Testbeds: A Study of the Impact of Network Latencies - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ashwin Rao
  • Fonction : Auteur
  • PersonId : 868330
Walid Dabbous
In this paper, we study the impact of network latency on the time required to download a file distributed using BitTorrent. This study is essential to understand if testbeds can be used for experimental evaluation of BitTorrent. We observe that the network latency has a marginal impact on the time required to download a file; hence, BitTorrent experiments can performed on testbeds.
impact-rtt.pdf (109.09 Ko) Télécharger le fichier
inria-00467560 , version 1 (26-03-2010)
  • HAL Id : inria-00467560 , version 1
  • ARXIV : 1003.5746
Ashwin Rao, Arnaud Legout, Walid Dabbous. BitTorrent Experiments on Testbeds: A Study of the Impact of Network Latencies. JDIR, 2010, Sophia Antipolis, France. ⟨inria-00467560⟩
291 Consultations
118 Téléchargements
