Towards a model of concurrent AOP - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Aspect-Oriented Programming (AOP) is concerned with the modularization of crosscutting functionalities. Such functionalities are problematic, in particular, for the development of concurrent applications, such as graphical user interfaces or multithreaded server applications. However, few approaches address this problem: there is, in particular, no general model for concurrent AOP that enables coordination among concurrently-executing aspects as well as coordination of concurrent aspects and base applications. In this paper, we discuss general requirements for such models, briefly present a specific instance meeting these requirements, and propose a set of general composition operators for the construction of concurrent applications using concurrently executing advice.
Douence-al-splat2006.pdf (318.68 Ko) Télécharger le fichier
inria-00468018 , version 1 (29-03-2010)
  • HAL Id : inria-00468018 , version 1
Rémi Douence, Didier Le Botlan, Jacques Noyé, Mario Südholt. Towards a model of concurrent AOP. SPLAT! 2006 - Workshop on Software engineering Properties of Languages and Aspect Technologies - A workshop affiliated with AOSD 2006, Mar 2006, Bonn, Germany. ⟨inria-00468018⟩
150 Consultations
77 Téléchargements
