Comparative Study of Routing Protocols for Mobile Ad Hoc Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2002
Thomas Clausen
Philippe Jacquet
Laurent Viennot
In this paper, we describe the Optimized Link State Routing Protocol (OLSR) [19],[20], a proactive routing protocol for Mobile Ad-hoc NETworks (MANETs). We evaluate its performance through exhaustive simulations using the Network Simulator 2 (ns2) [1], and compare with other ad-hoc protocols, specifically the Ad-hoc On-Demand Distance Vector (AODV) [4] routing protocol and the Dynamic Source Routing (DSR) [5] protocol. We study the protocols under varying conditions (node mobility, network density) and with varying traffic (TCP, UDP, different number of connections/streams) to provide a qualitative assessment of the applicability of the protocols in different scenarios.
medhocnet2002sim.pdf (139.47 Ko) Télécharger le fichier
inria-00471702 , version 1 (08-04-2010)
  • HAL Id : inria-00471702 , version 1
Thomas Clausen, Philippe Jacquet, Laurent Viennot. Comparative Study of Routing Protocols for Mobile Ad Hoc Networks. Med-hoc-Net, Sep 2002, Sardegna, Italy. ⟨inria-00471702⟩
464 Consultations
940 Téléchargements
