A nonlinear canonical form for reduced order observer design
This paper presents a nonlinear canonical form which is used for the design of a reduced order observer. Sufficient and necessary geometric conditions are given in order to transform a special class of nonlinear systems to the proposed nonlinear canonical form and the corresponding reduced order observer is analyzed.
Automatique
