Agenda-based routing in DTNs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We propose Price, an agenda-based greedy forwarding scheme for disruption-tolerant networks (DTN). Price combines greedy geographic forwarding with greedy contact-based forwarding by relying only on agendas of locations and agendas of contacts, which benefit from the inherent periodicity of mobility. While nodes construct their “social” environment of acquaintances through agendas of contacts, the pertinence of using greedy geographic forwarding is assessed by empirical evidences on the small world phenomenon in spatial mobility. The performance of the combination of these two forwarding modes in the Dartmouth College mobility data set comforts our analysis as we outperform PRoPHET and Bubble in terms of delivery ratio and cost. Furthermore, Price shows equivalent performance of the centralized version of Bubble.
boc_Algotel10.pdf (77.23 Ko) Télécharger le fichier
inria-00476488 , version 1 (26-04-2010)
  • HAL Id : inria-00476488 , version 1
Mathias Boc, Anne Fladenmuller, Marcelo Dias de Amorim, Sergio Palazzo. Agenda-based routing in DTNs. 12èmes Rencontres Francophones sur les Aspects Algorithmiques de Télécommunications (AlgoTel), May 2010, Belle Dune, France. pp.1-4. ⟨inria-00476488⟩
86 Consultations
153 Téléchargements
