Decentralized Approach for Execution of Composite Web Services using the Chemical Paradigm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2010
Nowadays, executions of composite Web services are typically conducted by heavyweight centralized engines. The cost of deploying a centralized engine is usually too high for a large number of small businesses or end-users and presents some weaknesses dealing with privacy issues. In addition, a centralized engine becomes a potential processing and communication bottleneck as well as a central point of failure. Therefore, problems and requirements, such as loose coupling, are pushing service infrastructures toward more decentralized and dynamic interaction schemes. In this paper, we propose a decentralized alternative system for the execution of composite Web services based on the chemical analogy. This chemical paradigm provides a high-level execution model that allows executing composite services in a fully decentralized manner. This system is composed by interconnected nodes communicating through a shared space containing both control and data flows, allowing to distribute part of the composition among nodes without the need for any centralized coordination.
RR-7267.pdf (318.74 Ko) Télécharger le fichier
inria-00476991 , version 1 (31-05-2010)
  • HAL Id : inria-00476991 , version 1
Héctor Fernandez, Thierry Priol, Cédric Tedeschi. Decentralized Approach for Execution of Composite Web Services using the Chemical Paradigm. [Research Report] RR-7267, INRIA. 2010, pp.16. ⟨inria-00476991⟩
195 Consultations
319 Téléchargements
