Introducing variability into Aspect-Oriented Modeling approaches - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
Aspect-Oriented Modeling (AOM) approaches propose to model reusable aspects, or cross-cutting concerns, that can be composed in different systems at a model or code level. Building complex systems with reusable aspects helps managing software complexity. But in gen- eral, reusability of an aspect is limited to a particular context. On the one hand, if the target model does not match the template point-to-point, the aspect cannot be applied. On the other hand, even when it is actually applied, it is woven into the target model always in the same way. In this paper1 , we point out the needs of variability in the AOM approaches and introduce seamless variability mechanisms in an existing AOM approach to improve reusability. Our aspects can fit various contexts and can be composed into the base model in different ways. Introducing variability into AOM approaches will turn standard aspects into highly reusable aspects.
Morin07b.pdf (701.21 Ko) Télécharger le fichier
inria-00477562 , version 1 (29-04-2010)
  • HAL Id : inria-00477562 , version 1
Philippe Lahire, Brice Morin, Gilles Vanwormhoudt, Alban Gaignard, Olivier Barais, et al.. Introducing variability into Aspect-Oriented Modeling approaches. In Proceedings of ACM/IEEE 10th International Conference on Model Driven Engineering Languages and Systems (MoDELS 07), 2007, Nashville, TN, USA, United States. ⟨inria-00477562⟩
395 Consultations
230 Téléchargements
