Model-Driven Engineering for Software Migration in a Large Industrial Context - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
As development techniques, paradigms and platforms evolve far more quickly than domain applications, software modernization and migration, is a constant challenge to software engineers. For more than ten years now, the Sodifrance company has been intensively using Model-Driven Engineering (MDE) for both development and migration projects. In this paper we report on the use of MDE as an efficient, flexible and reliable approach for a migration process (reverse-engineering, transformation and code generation). Moreover, we discuss how MDE is economically profitable and is cost-effective over the migration through out-sourced manual re-development. The paper is illustrated with the migration of a large-scale banking system from Mainframe to J2EE.
fleurey07a.pdf (590.04 Ko) Télécharger le fichier
inria-00477566 , version 1 (29-04-2010)
  • HAL Id : inria-00477566 , version 1
Franck Fleurey, Erwan Breton, Benoit Baudry, Alain Nicolas, Jean-Marc Jézéquel. Model-Driven Engineering for Software Migration in a Large Industrial Context. MoDELS'07, 2007, Nashville, TN, USA, United States. ⟨inria-00477566⟩
2947 Consultations
760 Téléchargements
