inria-00482939, version 1
Efficient implementation of a rake receiver on the TMS320C64x
Daniel Menard
a, 1Michel Guitton
a, 1Philippe Quémerais a, 1Sébastien Pillement
a, 1Olivier Sentieys
a, 1
Conference Record of the Thirty-Seventh Asilomar Conference on Signals, Systems and Computers, 2003 (2003)
Résumé : The evolution of radio-communication systems to third generation based on the WCDMA technique leads to an increase of the digital signal processing complexity. Due to their flexibility, high-performance DSP processors are good candidates for the platform used in radio-communication infrastructures. In this paper, an efficient implementation of a WCDMA rake receiver on the Texas Instrument TMS320C64x VLIW DSP is proposed. For minimizing the code execution time, the optimization techniques based on the exploitation of the data and instruction-level parallelism are presented.
- a – Université de Rennes 1
- 1 : R2D2 (INRIA - IRISA)
- CNRS : UMR6074 – INRIA – Institut National des Sciences Appliquées (INSA) - Rennes – Ecole Nationale Supérieure des Sciences Appliquées et de Technologie (ENSSAT) – Université de Rennes 1
- Domaine : Informatique/Traitement du signal et de l'image
Sciences de l'ingénieur/Traitement du signal et de l'image
- inria-00482939, version 1
- http://hal.inria.fr/inria-00482939
- oai:hal.inria.fr:inria-00482939
- Contributeur : Daniel Menard
- Soumis le : Mercredi 12 Mai 2010, 07:18:57
- Dernière modification le : Lundi 17 Mai 2010, 14:52:01
Documents associés
Exporter
