Supervisory Control and Deadlock Avoidance Control Problem for Concurrent Discrete Event Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
In this paper, we tackle the Supervisory Control Problem control for Concurrent Discrete Event Systems. These are systems that are defined by a collection of components that interact with each other. In this study, we first outline the method allowing to solve the state avoidance control problem on concurrent system, without having to compute the whole system. We then present results offering an efficient method to detect deadlock states in the controlled system due either to the composition or to the control that is performed on the system
2005-CDC-Blocking.pdf (187.83 Ko) Télécharger le fichier
inria-00483911 , version 1 (17-05-2010)
  • HAL Id : inria-00483911 , version 1
Benoit Gaudin, Hervé Marchand. Supervisory Control and Deadlock Avoidance Control Problem for Concurrent Discrete Event Systems. 44nd IEEE Conference on Decision and Control (CDC'05) and Control and European Control Conference ECC 2005, Dec 2005, Seville, Spain. pp.2763-2768. ⟨inria-00483911⟩
50 Consultations
148 Téléchargements
