Experimental study of the HUM control operator for waves - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We consider the problem of the numerical approximation of the linear controllability of waves. All our experiments are done in a bounded domain $\Omega$ of the plane, with Dirichlet boundary conditions and internal control. We use a Galerkin approximation of the optimal control operator of the continuous model, based on the spectral theory of the Laplace operator in $\Omega$. This allows us to obtain surprisingly good illustrations of the main theoretical results available on the controllability of waves, and to formulate some questions for the future analysis of optimal control theory of waves.
Picof10-Nodet.pdf (278.03 Ko) Télécharger le fichier
inria-00484092 , version 1 (18-05-2010)
  • HAL Id : inria-00484092 , version 1
Maëlle Nodet, Gilles Lebeau. Experimental study of the HUM control operator for waves. PICOF'10 - V International Conference on Inverse Problems, Control and Shape Optimization, Apr 2010, Cartagena, Spain. ⟨inria-00484092⟩
198 Consultations
180 Téléchargements
