Indoor Positioning using the IEEE 802.11 Infrastructure - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2010
Philippe Jacquet
Yacine Mezali
  • Fonction : Auteur
  • PersonId : 871291
We propose a new indoor localization method which can be used to track a mobile node . Our method uses only the received signal strengths as input information . In addition our approach doesn't require any prior knowledge of the mobile node's motion and therefore doesn't use a cinematic motion model for tracking the mobile node. We discuss in detail the features of our approach and its resulting algorithm .We evaluate the performances of our algorithm using a real signal map.
RR-7294.pdf (624.22 Ko) Télécharger le fichier
inria-00485454 , version 1 (29-06-2010)
  • HAL Id : inria-00485454 , version 1
Philippe Jacquet, Yacine Mezali, Georgios Rodolakis. Indoor Positioning using the IEEE 802.11 Infrastructure. [Research Report] RR-7294, INRIA. 2010. ⟨inria-00485454⟩
180 Consultations
151 Téléchargements
