XML Translation Workflow - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
Customization of Machine Translation (MT) is a prerequisite for corporations to adopt the technology. It is therefore important but nonetheless challenging. Ongoing implementation proves that XML is an excellent exchange device between MT modules that efficiently enables interaction between the user and the processes to reach highly granulated structure-based customization. Accomplished through an innovative approach called the SYSTRAN Translation Stylesheet, this method is coherent with the current evolution of the “authoring process”. As a natural progression, the next stage in the customization process is the integration of MT in a multilingual tool kit designed for the “authoring process”.
2003.09.The.XML.Translation.Workflow.pdf (307.06 Ko) Télécharger le fichier
inria-00487747 , version 1 (31-05-2010)
  • HAL Id : inria-00487747 , version 1
Jean Sénellart, Christian Boitet, Laurent Romary. XML Translation Workflow. Machine Translation Summit IX, Sep 2003, New Orleans, United States. ⟨inria-00487747⟩
219 Consultations
167 Téléchargements
