s'authentifier
version française rss feed
inria-00490108, version 4
Accurate emulation of CPU performance
Tomasz Buchert () 1, Lucas Nussbaum () 1, Jens Gustedt () 1
8th International Workshop on Algorithms, Models and Tools for Parallel Computing on Heterogeneous Platforms - HeteroPar'2010 (2010)
Résumé : This paper addresses the question of CPU performance emulation, which allows experimenters to evaluate applications under a wide range of reproducible experimental conditions. Specifically, we propose Fracas, a CPU emulator that leverages the Linux Completely Fair Scheduler to achieve performance emulation of homogeneous or heterogeneous multi-core systems. Several benchmarks reproducing different types of workload (CPU-bound, IO-bound) are then used to thoroughly compare Fracas with another CPU emulator and hardware frequency scaling. We show that the design of Fracas results in a more accurate and a less intrusive CPU emulation solution.
  • 1 :  ALGORILLE (INRIA Lorraine - LORIA)
  • INRIA – CNRS : UMR7503 – Université Henri Poincaré - Nancy I – Université Nancy II – Institut National Polytechnique de Lorraine (INPL)
  • Collaboration : Grid'5000
  • inria-00490108, version 4
  • oai:hal.inria.fr:inria-00490108
  • Contributeur :
  • Soumis le : Vendredi 23 Septembre 2011, 16:22:08
  • Dernière modification le : Jeudi 12 Avril 2012, 14:41:59
tous les articles de la base du CCSd...
