K-Shell Decomposition for Dynamic Complex Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Abstract—K-shell (or k-core) graph decomposition methods were introduced as a tool for studying the structure of large graphs. K-shell decomposition methods have been recently proposed [1] as a technique for identifying the most influential spreaders in a complex network. Such techniques apply to static networks, whereby the topology does not change over time. In this paper we address the problem of extending such a framework to dynamic networks, whose evolution over time can be characterized through a pattern of contacts among nodes. We propose two methods for ranking nodes, according to generalized k-shell indexes, and compare their ability to identify the most influential spreaders by emulating the diffusion of epidemics using both synthetic as well as real–world contact traces.
p499-miorandi.pdf (813.29 Ko) Télécharger le fichier
inria-00492057 , version 1 (15-06-2010)
  • HAL Id : inria-00492057 , version 1
Daniele Miorandi, Francesco de Pellegrini. K-Shell Decomposition for Dynamic Complex Networks. WiOpt'10: Modeling and Optimization in Mobile, Ad Hoc, and Wireless Networks, May 2010, Avignon, France. pp.499-507. ⟨inria-00492057⟩
Collections
WIOPT2010
102 Consultations
2081 Téléchargements
