s'authentifier
version française rss feed
inria-00492058, version 1
Static community detection algorithms for evolving networks
Thomas Aynaud 1, Jean-Loup Guillaume () 1
WiOpt'10: Modeling and Optimization in Mobile, Ad Hoc, and Wireless Networks (2010) 508-514
Résumé : Complex networks can often be divided in dense sub-networks called communities. Using a partition edit distance, we study how three community detection algorithms transform their outputs if the input network is slightly modified. The instabilities appear to be important and we propose a modification of one algorithm to stabilize it and to allow the tracking of the communities in an evolving network. This modification has one parameter which is a tradeoff between stability and quality. The resulting algorithm appears to be very effective. We finally use it on an evolving network of blogs.
  • Collaboration : Workshop 05 : Workshop on Dynamic Networks
  • Domaine : Informatique/Réseaux et télécommunications
  • Mots-clés : complex networks – evolving communities – stability – tracking – blogs
tous les articles de la base du CCSd...
