KnightShift: Shifting the I/O Burden in Datacenters to Management Processor for Energy Efficiency - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Data center energy costs are growing concern. Many datacenters use direct-attached-storage architecture where data is distributed across disks attached to several servers. In this organization even if a server is not utilized it can not be turned off since each server carries a fraction of the permanent state needed to complete a request. Operating servers at low utilization is very inefficient due to the lack of energy proportionality. In this research we propose to use outof- band management processor, typically used for remotely managing a server, to satisfy I/O requests from a remote server. By handling requests with limited processing needs, the management processor takes the load off the primary server thereby allowing the primary server to sleep when not actively being used; we call this approach KnightShift. We describe how existing management processors can be modified to handle KnightShift responsibility. We use several production datacenter traces to evaluate the energy impact of KnightShift and show that energy consumption can be reduced by 2.6X by allowing management processors to handle only those requests that demand less than 5
WEED-ghosh.pdf (1.84 Mo) Télécharger le fichier
inria-00492845 , version 1 (17-06-2010)
  • HAL Id : inria-00492845 , version 1
Sabyasachi Ghosh, Mark Redekopp, Murali Annavaram. KnightShift: Shifting the I/O Burden in Datacenters to Management Processor for Energy Efficiency. WEED 2010 - Workshop on Energy-Efficient Design, Jun 2010, Saint Malo, France. ⟨inria-00492845⟩
Collections
WEED2010 ISCA2010
66 Consultations
215 Téléchargements
