Dynamic Power Redistribution in Failure Prone CMPs
Future chip multiprocessors (CMPs) will be capable of deconfiguring faulty units in order to permit continued operation in the presence of wear-out failures. However, the unforeseen downside is pipeline imbalance due to other portions of the pipeline now being overprovisioned with respect to the deconfigured functionality. We propose PowerTransfer, a novel CMP architecture that dynamically redistributes the chip power under pipeline imbalances that arise from deconfiguring faulty units. Through rebalancing – achieved by temporary, symbiotic deconfiguration of additional functionality within the degraded core – power is harnessed for use elsewhere on the chip. This additional power is dynamically transferred to portions of the multi-core chip that can realize a performance boost from turning on previously dormant microarchitectural features. We demonstrate that a realistic PowerTransfer manager achieves chip-wide performance improvements of up to 25% compared to architectures that simply deconfigure faulty units without regard to the resulting inefficiency.
Architectures Matérielles [cs.AR]
