Adaptive Subset Based Replacement Policy for High Performance Caching - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
An Adaptive Subset Based Replacement Policy (ASRP) is proposed in this paper. In ASRP policy, each set in Last-Level Cache (LLC) is divided into multiple subsets, and one subset is active and others are inactive at a given time. The victim block for a miss is only chosen from the active subset using LRU policy. A counter in each set records the cache misses in the set during a period of time. When the value of the counter is greater than a threshold, the active subset is changed to the neighbor one. To adapt the program behavior changing, set dueling is used to choose a threshold from different thresholds according to which one causes the least number of misses in the sampling sets. Using the given framework for this competition our ASRP policy gets a geometric average of improvement over LRU by 4.5% for 28 SPEC CPU 2006 programs and some programs gain improvements up to 50%.
008_he.pdf (125.12 Ko) Télécharger le fichier
inria-00492980 , version 1 (17-06-2010)
  • HAL Id : inria-00492980 , version 1
Liqiang He, Yan Sun, Chaozhong Zhang. Adaptive Subset Based Replacement Policy for High Performance Caching. JWAC 2010 - 1st JILP Worshop on Computer Architecture Competitions: cache replacement Championship, Jun 2010, Saint Malo, France. ⟨inria-00492980⟩
Collections
ISCA2010 JWAC2010
98 Consultations
62 Téléchargements
