On the Use of Small 2D Convolutions on GPUs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Computing many small 2D convolutions using FFTs is a basis for a large number of applications in many domains in science and engineering, among them electromagnetic diffraction modeling in physics. The GPU architecture seems to be a suitable architecture to accelerate these convolutions, but reaching high application performance requires substantial development time and non-portable optimizations. In this work, we present the techniques, performance results and considerations to accelerate small 2D convolutions using CUDA, and compare performance to a multi-threaded CPU implementation. To improve programmability and performance of applications that make heavy use of small convolutions, we argue that two improvements to software and hardware are needed: FFT libraries must be extended with a single convolution function and communication bandwidth between CPU and GPU needs to be drastically improved.
A4MMC-al-umairy.pdf (202.58 Ko) Télécharger le fichier
inria-00493873 , version 1 (21-06-2010)
  • HAL Id : inria-00493873 , version 1
Shams A.H. Al Umairy, Alexander S. van Amesfoort, Irwan D. Setija, Martijn C. van Beurden, Henk J. Sips. On the Use of Small 2D Convolutions on GPUs. A4MMC 2010 - 1st Workshop on Applications for Multi and Many Core Processors, Jun 2010, Saint Malo, France. ⟨inria-00493873⟩
Collections
ISCA2010 A4MMC
60 Consultations
735 Téléchargements
