Towards User Transparent Parallel Multimedia Computing on GPU-clusters - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The research area of Multimedia Content Analysis (MMCA) considers all aspects of the automated extraction of knowledge from multimedia archives and data streams. To satisfy the increasing computational demands of MMCA problems, the use of High Performance Computing (HPC) techniques is essential. As most MMCA researchers are not HPC experts, there is an urgent need for 'familiar' programming models and tools that are both easy to use and efficient. Today, several user transparent library-based parallelization tools exist that aim to satisfy both these requirements. In general, such tools focus on data parallel execution on traditional compute clusters. As of yet, none of these tools also incorporate the use of many-core processors (e.g. GPUs), however. While traditional clusters are now being transformed into GPU-clusters, programming complexity vastly increases — and the need for easy and efficient programming models is as urgent as ever. This paper presents our first steps in the direction of obtaining a user transparent programming model for data parallel and hierarchical multimedia computing on GPU-clusters. The model is obtained by extending an existing user transparent parallel programming system (applicable to traditional compute clusters) with a set of CUDA compute kernels. We show our model to be capable of obtaining orders-of-magnitude speed improvements, without requiring any additional effort from the application programmer.
A4MMC-werkhoven.pdf (204.49 Ko) Télécharger le fichier
inria-00493883 , version 1 (21-06-2010)
  • HAL Id : inria-00493883 , version 1
Ben van Werkhoven, Jason Maassen, Frank J. Seinstra. Towards User Transparent Parallel Multimedia Computing on GPU-clusters. A4MMC 2010 - 1st Workshop on Applications for Multi and Many Core Processors, Jun 2010, Saint Malo, France. ⟨inria-00493883⟩
Collections
ISCA2010 A4MMC
34 Consultations
278 Téléchargements
