Sequential Execution of Parallel Programs :). Threads Should not Play Dice. (Keynote Talk) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Document Associé À Des Manifestations Scientifiques Année : 2010
Current multicore systems are nondeterministic. Each time they execute a multithreaded application, even if supplied with the same input, they can produce a different output. This frustrates debugging, limits the ability to properly test multithreaded code and hinders fault-tolerant scenarios.
PESPMA-ceze-court.pdf (223.45 Ko) Télécharger le fichier
inria-00494298 , version 1 (22-06-2010)
  • HAL Id : inria-00494298 , version 1
Luis Ceze. Sequential Execution of Parallel Programs :). Threads Should not Play Dice. (Keynote Talk). Pespma 2010 - Workshop on Parallel Execution of Sequential Programs on Multi-core Architecture, Jun 2010, Saint Malo, France. ⟨inria-00494298⟩
12 Consultations
0 Téléchargements
