Model-free control of dc/dc converters - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A new "model-free" control methodology is applied for the first time to power converters, and in particular to a buck converter, and to a Cuk converter. We evaluate its performances regarding load and supply variations. Our approach, which utilizes "intelligent" PI controllers, does not require any converter identification while ensuring the stability and the robustness of the control synthesis. Simulation and experimental results show that, with a simple control structure, insensitivity to power supply fluctuations and to large load variations is ensured.
COMPEL2010.pdf (1.42 Mo) Télécharger le fichier
inria-00495776 , version 1 (29-06-2010)
Loïc Michel, Cédric Join, Michel Fliess, Pierre Sicard, Ahmed Chériti. Model-free control of dc/dc converters. 12th IEEE Workshop on Control and Modeling for Power Electronics (COMPEL), Jun 2010, Boulder, Colorado, United States. pp.CDROM, ⟨10.1109/COMPEL.2010.5562385⟩. ⟨inria-00495776⟩
737 Consultations
1759 Téléchargements
