Dynamic Self-Organising Map - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Neurocomputing Année : 2011
Nicolas P. Rougier
Yann Boniface
  • Fonction : Auteur
  • PersonId : 835315
We present in this paper a variation of the self-organising map algorithm where the original time-dependent (learning rate and neighbourhood) learning function is replaced by a time-invariant one. This allows for on-line and continuous learning on both static and dynamic data distributions. One of the property of the newly proposed algorithm is that it does not fit the magnification law and the achieved vector density is not directly proportional to the density of the distribution as found in most vector quantisation algorithms. From a biological point of view, this algorithm sheds light on cortical plasticity seen as a dynamic and tight coupling between the environment and the model.
Neurosciences
draft-revised.pdf (1.6 Mo) Télécharger le fichier
inria-00495827 , version 1 (29-06-2010)
Nicolas P. Rougier, Yann Boniface. Dynamic Self-Organising Map. Neurocomputing, 2011, 74 (11), pp.1840-1847. ⟨10.1016/j.neucom.2010.06.034⟩. ⟨inria-00495827⟩
512 Consultations
3013 Téléchargements
