Enhanced Dependency Structure Matrix for Moose - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Dependency Structure Matrix (DSM), an approach de- veloped in the context of process optimization, has been suc- cessfully applied to identify software dependencies among packages and subsystems. It exists a couple of algorithms to help organizing the matrix in a form that reflects the ar- chitecture and highlights patterns and problematic depen- dencies between subsystems. However, the existing DSM implementations often miss some important information in their visualization to fully support a reengineering effort. In this paper we enhanced DSM with enriched cell contextual information by showing information (i) about the kinds of references made (inheritance, class accesses..), (ii) the pro- portion of entities (classes/methods) doing references, (iii) the proportion of entities been the target of the references. We distinguish independent cycles and stress the cycles us- ing coloring information. This work has been implemented on top of the Moose open-source reengineering environment and Mondrian. It has been applied to non-trivial case stud- ies such as the Morphic UI frameworks available in Squeak an open-source Smalltalk.
Berg08c-Famoosr2008-DSM.pdf (371.63 Ko) Télécharger le fichier
inria-00498484 , version 1 (07-07-2010)
  • HAL Id : inria-00498484 , version 1
Alexandre Bergel, Stéphane Ducasse, Jannik Laval, Romain Piers. Enhanced Dependency Structure Matrix for Moose. FAMOOSr, Oct 2008, Antwerp, Belgium. ⟨inria-00498484⟩
164 Consultations
69 Téléchargements
