Virtual MIMO Network A Physical Wireless Analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Jean-Marc Kelif
  • Fonction : Auteur
  • PersonId : 834623
By analogy with an approach widely used in physics, we consider a discrete set of base stations (BS) as a continuum of transmitters. This model allows us to establish a simple closedform formula of the interferences and the SINR received by a mobile, whatever its location. As an application of this model, we propose an analytical study of a virtual MIMO network. Indeed, we consider that the useful power received by each user of a cell is the sum of useful powers coming from all base stations of the network. The physical wireless network model enables to quantify, in a simple way, the impact of virtual MIMO on the instantaneous throughput. We moreover show that the outage probability increases.
p418-kelif.pdf (502.27 Ko) Télécharger le fichier
inria-00499401 , version 1 (09-07-2010)
  • HAL Id : inria-00499401 , version 1
Jean-Marc Kelif. Virtual MIMO Network A Physical Wireless Analysis. WiOpt'10: Modeling and Optimization in Mobile, Ad Hoc, and Wireless Networks, May 2010, Avignon, France. pp.418-425. ⟨inria-00499401⟩
Collections
WIOPT2010
34 Consultations
106 Téléchargements
